420A Plug Gap
Blitzeclips
1,571
6
Aug 5, 2004
Bear, Delaware
Would there be any altering of this needed during the install? Can I leave the stock gap where it is @ 8psi?
I was thinking of setting it to .28 or .29 after some tuning and uping the boost to keep my idle consistant.
If anyone knows or can help out here, please do! TIA guys..
The only time you need to go below .028 is if you're running high boost numbers and the spark is being blown out. Without an MSD, I'd run .026 or .024 at 26 psi or more, but with one, I can still run .030 without a problem. Leave it at .028 and you'll be fine. If it stutters at all and you know the plugs and wires are good, drop it to .026 and see if it improves.
Hope that helps,
Andy
So leave it stock until I turn up the boost?
If I'm missing under boost close the gap gradually until it runs properly?
hmm... Thats interesting..
From my assumptions, the further the spark equals less feul burnt because its got a larger gap from the pistons... Runnning the gaps closer would give more feul therefore creating a stronger spark under higher pressure (AKA-Boost)
Sound correct? I want to know why the gaps are altered so I can understand the sytem better for future reference..
So enlighten me if I'm wrong.. or off per se..
Thanks again guys. :thumb:
From http://www.ngksparkplugs.com/techinfo/spark_plugs/installation.asp?nav=31300&country=US
"Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark."
How big a gap you can run is depends on the rest of the ignition system but the goal is to run as big a gap as you can and not misfire.
A couple more references:
http://www.ngkntk.co.uk/technicaltips/sparkpluggap.asp
http://en.wikipedia.org/wiki/Spark_plug#Spark_plug_gap
Steve
  • For sale 2g 2G OEM Non Cruise Throttle Cable
    2G OEM Non Cruise Throttle Cable $50 + shipping & paypal feesYou must be registered to see...
  • Wanted 2g 1995 Eclipse GS-T Driver door cap wanted
    I'm looking for a 1995 GS-T driver side door cap or even a complete door with the proper door cap.
    • loco4G63
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
