blackhawk2k7
- 98
- 0
- Oct 12, 2008
Stanwood,
Washington
ok so iam looking at getting a simple 2 gauge pillar mount, however right now, just above the radio double-din is the current mount for my EGT and boost gauges, the easy part would be re-routing the wires, the hard is what iam inquiring about, the vacuum line off the back of the boost gauge is cut-to-length to fit the spot currently, where would the other end of it be for when i re-route the line to the pillar? or could i tap another line with a connector on the vacuum line currently and route it up to the pillar?
thanks,
BHawk
thanks,
BHawk
