passenger side window doesnt roll down!!
chrispix
84
Oct 6, 2002
Portland, Oregon
i rolled both windows down instead of using my ac. when i got to my destination, i couldnt roll the passenger side window up. i cycled the window lock button and pressed the switch to no avail. i pulled the trim panel off to see if i could pull the window up manually, but i couldnt find a way. all this right before work in the beginning of a hectic week. seems like that is how it always happens.
anyways, anybody know how to roll an electric window up manually? or what the problem is with the window?
thanks
haha, while i was checking my post, i noticed i might have left the window lock button in the lock position after cycling it with the drivers side window switch (brain fart). so i just went back down to the car, pushed the lock button one time, plugged the passenger side window switch back in and...presto!! the window rolled up when i pushed the switch. i retested the driver side switch and it still doesnt work. so now i know that the driver side window switch for the passenger window is toast (unless an expert on this board knows different). does anybody know the OEM p/n for the switch?
thanks
thanks
Same exact problem here and w/5 gauges, SAFC, TT, and CD player I couldn't afford to keep that window down heh. Your going to have to take the door panel off in order to get the window back up.
