Part numbers for a refresher??
VyperFox
41
Apr 17, 2009
Richmond, Virginia
Hi all, its been about a few months or so and this evil car has been leaking oil driving me up the wall, i did replace the crank seal and oil pump seal, but that seemed to make it worst, im about to pull the engine out again, and applie new gaskets on seal in the front of the engine, since i cannot do it with the engine in that car, ive read some where that the oil pump is holding the front case(wich is leaking badly in mine) to the block, im including a small list with pnc and mitsu numbers, just wondering if some one can look it over and see if i need anything else to add to my part buying list, all help is appreciated, thanks to all who view this post. btw the dsm im working on is a 1g non turbo 7bolt 10/92
front case
PNC P/N 1 P/N 2 NAME QTY
02000A MD193384 MD327450 FRONT CASE ASSY 1
02097Q MF140225 M8X20X1.25 5
04199P MF241261 M8X40X1.25 2
04199S MF241266 M8X65X1.25 2
04199Q MF241268 M8X70X1.25 1
02097T MF140230 M8X32X1.25 1
02097X MF140227 M8X25X1.25 1
02097V MF140233 M8X40X1.25 1
03070* MD174462 MD343563 OIL SEAL, CRANK 1
04028* MD095355 MD365697 OIL SEAL, OIL PUMP 1
03623R MD069950 MD343565 OIL SEAL, BAL SHAFT 1
02017* MD187905 GASKET, ENG FR CASE 1
04114* MD185528 GASKET, OIL FILTER BR 1
02092* MD125376 PLUG, ENG FR CASE 1
02099* MD041021 O-RING, ENG FR CASE 1
04102A MD189931 MD191753 BRACKET ASSY, OIL FIL 1
THROTTLE BODY
07727* MD147286 MD147287 STAY, THROTTLE BODY 1
07710* MD192535 MD194578 GASKET. THROTTLE BODY 1
07794* MF450405 WASHER, THROTTLE BODY SPRING, M8 2
07797* MF430121 NUT, THROTTLE BODY, M8X1.25 2
07798P MF241270(M8X85X1.25) MF241264(M8X55X1.25) BOLT, THROTTLE BODY WASHER ASSEMBLED 2
EXHAUST
02200P MD130498 ENGINE HANGER 1
02299P MF244249 BOLT, ENGINE HANGER WASHER ASSEMBLED 1
