Part Number for 2g Transmission End Case
slipstream808
773
6
Mar 2, 2005
State College, Pennsylvania
I just wanted to let everyone know the part number for the 2g 5th gear cover end case that is stamped on the end cover itself is apparently wrong. Stamped on it is:
MD742105
I called JNZTuning to get a new one and Eric said it wasn't in the system. He ordered me one that would fit all 95-99's (2g). Well it came in, part number
MD742106 <----What you want!
But still stamped on the inside of the case was MD742105. So I dunno why but that is not correct for ordering a new part. And FYI, it does not include the wave spring, the 3 hex head bolts or the bracket that the hex head bolts hold down.
Hope this helps someone!
The 5th gear cover part numbers are the following:
1G FWD: MD734477
1G (1989-Early 1991) AWD: MD735344
1G (Late 1991-1994) AWD: MD741184
2G FWD: MD742106
2G AWD: MD741184
The Reverse Cone is the same for ALL models:
MD725928
The Reverse Cone Screws are the same for ALL models:
3 x MD736513 (M5 X 7.5mm machine screw)
The Reverse Wave Spring is the same for ALL models:
MD744342
The 5th Gear Cover Dowels are:
2 x MF472402
Check aaaand mate! You trumped me!
