2G Opinion on my recent compression test
Snailtrail420
32
4
Feb 5, 2022
Halifax, NS, Canada
I recently just compression tested my 4g63 7 bolt engine again. It has been sitting cold for a good 7 years without running. When i had it apart i cleaned up intake and and exhaust valves etc. Compression test results show, 180, 180, 150, 180.
I tested them all a couple times with similar results each test. I wonder if its fine to run with the one cylinder a bit past 10% variance. Eventually would look into rebuilding if it gets worse, but does seem a little low.
