Opinion on my log after SAFC tuning
joeyzaza
128
Jul 19, 2008
muskegon, Michigan
Here is my log. I think I'm getting closer, can I go leaner on the SAFC?? The o2 voltage shows rich still I believe.
Before I get bashed, I'm saving for a wideband :thumb:
[/url][/IMG]
There's no telling where your AFR's are. With the timing so low, it would almost sound as though you have knock. Do you have any logs that include knock readings?
The problem is that you're showing a log with several maxed out readings, so the probability of a correct tune is very low.
I have a 2g so I can't log knock. I'm going by o2 voltage and timing. I thought that most people tuning off of just loggers on 2gs, shoot for around mid .90s on o2. Am I wrong??
I believe there are other ways to log knock, but not necessarily through the palm logger. The problem I see is that your readings are not around .9, they are just maxed out as they approach 1.0.
I would guess that the maximum reading your logger will pick up for the O2 sensor is 0.976, just like your TPS is showing 97.6%.
This log just shows you're running rich. How rich? Who knows, just that's less than 14.0 (or wherever the relative frequency range is). Can this cause a problem? Yes, at the very least it will burn up your cat.
Here is the whole log.
Code:
<html xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:x="urn:schemas-microsoft-com:office:excel"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 11">
<link rel=File-List href="log1_files/filelist.xml">
<link rel=Edit-Time-Data href="log1_files/editdata.mso">
<link rel=OLE-Object-Data href="log1_files/oledata.mso">
<!--[if gte mso 9]><xml>
 <o:DocumentProperties>
  <o:LastAuthor> </o:LastAuthor>
  <o:Created>2009-03-17T01:56:33Z</o:Created>
  <o:LastSaved>2009-03-17T02:10:38Z</o:LastSaved>
  <o:Version>11.5606</o:Version>
 </o:DocumentProperties>
</xml><![endif]-->
<style>
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
@page
	{margin:1.0in .75in 1.0in .75in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;}
tr
	{mso-height-source:auto;}
col
	{mso-width-source:auto;}
br
	{mso-data-placement:same-cell;}
.style0
	{mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	white-space:nowrap;
	mso-rotate:0;
	mso-background-source:auto;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	border:none;
	mso-protection:locked visible;
	mso-style-name:Normal;
	mso-style-id:0;}
td
	{mso-style-parent:style0;
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>EvoScanDataLog_2009.03.16_19.39</x:Name>
    <x:WorksheetOptions>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
       <x:Number>3</x:Number>
       <x:ActiveRow>3</x:ActiveRow>
       <x:ActiveCol>12</x:ActiveCol>
      </x:Pane>
     </x:Panes>
     <x:ProtectContents>False</x:ProtectContents>
     <x:ProtectObjects>False</x:ProtectObjects>
     <x:ProtectScenarios>False</x:ProtectScenarios>
    </x:WorksheetOptions>
   </x:ExcelWorksheet>
  </x:ExcelWorksheets>
  <x:WindowHeight>9720</x:WindowHeight>
  <x:WindowWidth>19035</x:WindowWidth>
  <x:WindowTopX>0</x:WindowTopX>
  <x:WindowTopY>15</x:WindowTopY>
  <x:ProtectStructure>False</x:ProtectStructure>
  <x:ProtectWindows>False</x:ProtectWindows>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=4160 style='border-collapse:
 collapse;table-layout:fixed;width:3120pt'>
 <col width=64 span=65 style='width:48pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 width=64 style='height:12.75pt;width:48pt'>TPS</td>
  <td width=64 style='width:48pt'>RPM</td>
  <td width=64 style='width:48pt'>TimingAdv</td>
  <td width=64 style='width:48pt'>AirFlow</td>
  <td width=64 style='width:48pt'>FuelTrim_<span style='display:none'>Low</span></td>
  <td width=64 style='width:48pt'>FuelTrim_<span style='display:none'>Mid</span></td>
  <td width=64 style='width:48pt'>FuelTrim_<span style='display:none'>High</span></td>
  <td width=64 style='width:48pt'>O2Feedba<span style='display:none'>ckTrim</span></td>
  <td width=64 style='width:48pt'>O2Sensor</td>
  <td width=64 style='width:48pt'>InjPulseWi<span style='display:none'>dth</span></td>
  <td width=64 style='width:48pt'>InjDutyCyc<span style='display:none'>le</span></td>
  <td width=64 style='width:48pt'>FuelConsu<span style='display:none'>mption</span></td>
  <td width=64 style='width:48pt'>Gear</td>
  <td width=64 style='width:48pt'>AirVol</td>
  <td width=64 style='width:48pt'>MAP</td>
  <td width=64 style='width:48pt'>JDMMAP</td>
  <td width=64 style='width:48pt'>WideBand<span style='display:none'>AF</span></td>
  <td width=64 style='width:48pt'>KnockSum</td>
  <td width=64 style='width:48pt'>ISCSteps</td>
  <td width=64 style='width:48pt'>CrankSign<span style='display:none'>alSw</span></td>
  <td width=64 style='width:48pt'>IdlePosSw</td>
  <td width=64 style='width:48pt'>PwrSteerin<span style='display:none'>gSw</span></td>
  <td width=64 style='width:48pt'>ACSwitch</td>
  <td width=64 style='width:48pt'>ACRelayS<span style='display:none'>w</span></td>
  <td width=64 style='width:48pt'>InhibitorSw</td>
  <td width=64 style='width:48pt'>AFRMAP</td>
  <td width=64 style='width:48pt'>LoadCalc</td>
  <td width=64 style='width:48pt'>Load11bit4</td>
  <td width=64 style='width:48pt'>ECULoad</td>
  <td width=64 style='width:48pt'>InjectorLat<span style='display:none'>ency</span></td>
  <td width=64 style='width:48pt'>LoadMUT2<span style='display:none'>Byte</span></td>
  <td width=64 style='width:48pt'>RPMMUT2<span style='display:none'>Byte</span></td>
  <td width=64 style='width:48pt'>AirFlowMU<span style='display:none'>T2Byte</span></td>
  <td width=64 style='width:48pt'>gRev</td>
  <td width=64 style='width:48pt'>LbsMin</td>
  <td width=64 style='width:48pt'>WHP</td>
  <td width=64 style='width:48pt'>Lbsft</td>
  <td width=64 style='width:48pt'>TestE1</td>
  <td width=64 style='width:48pt'>TestE4</td>
  <td width=64 style='width:48pt'>Knock</td>
  <td width=64 style='width:48pt'>OctaneFla<span style='display:none'>g</span></td>
  <td width=64 style='width:48pt'>knock_adc</td>
  <td width=64 style='width:48pt'>knock_bas<span style='display:none'>e</span></td>
  <td width=64 style='width:48pt'>knock_var</td>
  <td width=64 style='width:48pt'>knock_cha<span style='display:none'>nge</span></td>
  <td width=64 style='width:48pt'>knock_dyn<span style='display:none'>amics</span></td>
  <td width=64 style='width:48pt'>knock_flag</td>
  <td width=64 style='width:48pt'>EGRTemp</td>
  <td width=64 style='width:48pt'>WGDC</td>
  <td width=64 style='width:48pt'>LoadError</td>
  <td width=64 style='width:48pt'>WGDCCor<span style='display:none'>r</span></td>
  <td width=64 style='width:48pt'>ZTXEGT</td>
  <td width=64 style='width:48pt'>ZTXBoost</td>
  <td width=64 style='width:48pt'>ZTXRPM</td>
  <td width=64 style='width:48pt'>ZTXTPS</td>
  <td width=64 style='width:48pt'>ZTXUser1</td>
  <td width=64 style='width:48pt'>ZTXConfig</td>
  <td width=64 style='width:48pt'>LC1RPM</td>
  <td width=64 style='width:48pt'>LC1Batter<span style='display:none'>y</span></td>
  <td width=64 style='width:48pt'>LC1Aux1</td>
  <td width=64 style='width:48pt'>LC1Aux2</td>
  <td width=64 style='width:48pt'>LC1Aux3</td>
  <td width=64 style='width:48pt'>LC1Aux4</td>
  <td width=64 style='width:48pt'>LC1Aux5</td>
  <td width=64 style='width:48pt'>Custom</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="21.960784313725501">21.96078</td>
  <td align=right x:num>2187.5</td>
  <td align=right x:num>31</td>
  <td align=right x:num>81.25</td>
  <td align=right x:num="10.4941">10.4941</td>
  <td align=right x:num="-0.48750000000000099">-0.4875</td>
  <td align=right x:num="0.1008">0.1008</td>
  <td align=right x:num="1.4735">1.4735</td>
  <td align=right x:num="0.11712">0.11712</td>
  <td align=right x:num="2.3039999999999998">2.304</td>
  <td align=right x:num>4.2</td>
  <td colspan=54 style='mso-ignore:colspan'></td>
 </tr>
  <td align=right x:num="2.8462000000000001">2.8462</td>
  <td align=right x:num="0.15615999999999999">0.15616</td>
 </tr>
  <td align=right x:num="4.2188999999999997">4.2189</td>
  <td align=right x:num="0.62463999999999997">0.62464</td>
 </tr>
  <td align=right x:num>30</td>
  <td align=right x:num="3.4344999999999999">3.4345</td>
  <td align=right x:num="0.81984000000000001">0.81984</td>
  <td align=right x:num="2.048">2.048</td>
  <td align=right x:num="3.7333333333333298">3.733333</td>
 </tr>
  <td align=right x:num="2.4540000000000002">2.454</td>
  <td align=right x:num>3.68</td>
 </tr>
  <td align=right x:num>2156.25</td>
  <td align=right x:num="0.23424">0.23424</td>
  <td align=right x:num>4.14</td>
 </tr>
  <td align=right x:num="3.8267000000000002">3.8267</td>
  <td align=right x:num="0.2928">0.2928</td>
 </tr>
  <td align=right x:num="0.83935999999999999">0.83936</td>
 </tr>
  <td align=right x:num="0.76127999999999996">0.76128</td>
 </tr>
  <td align=right x:num="1.8656999999999999">1.8657</td>
  <td align=right x:num="0.72223999999999999">0.72224</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="22.352941176470601">22.35294</td>
  <td align=right x:num="0.19520000000000001">0.1952</td>
 </tr>
  <td align=right x:num>87.5</td>
  <td align=right x:num="3.2383999999999999">3.2384</td>
  <td align=right x:num="0.25375999999999999">0.25376</td>
 </tr>
  <td align=right x:num="0.85887999999999998">0.85888</td>
 </tr>
  <td align=right x:num="2.6501000000000001">2.6501</td>
  <td align=right x:num="0.78080000000000005">0.7808</td>
  <td align=right x:num>4.08</td>
 </tr>
  <td align=right x:num>2125</td>
  <td align=right x:num="1.6696">1.6696</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="22.745098039215701">22.7451</td>
  <td align=right x:num="0.68910000000000005">0.6891</td>
  <td align=right x:num="0.39040000000000002">0.3904</td>
 </tr>
  <td align=right x:num="0.76800000000000002">0.768</td>
  <td align=right x:num>1.38</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="37.647058823529399">37.64706</td>
  <td align=right x:num>28</td>
  <td align=right x:num>200</td>
  <td align=right x:num="3.9039999999999998E-2">0.03904</td>
  <td align=right x:num>1.52</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="62.352941176470601">62.35294</td>
  <td align=right x:num>2375</td>
  <td align=right x:num>22</td>
  <td align=right x:num>275</td>
  <td align=right x:num="0.13664000000000001">0.13664</td>
  <td align=right x:num="6.6559999999999997">6.656</td>
  <td align=right x:num="13.6933333333333">13.69333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="97.647058823529406">97.64706</td>
  <td align=right x:num>2468.75</td>
  <td align=right x:num>20</td>
  <td align=right x:num>306.25</td>
  <td align=right x:num="0.91744000000000003">0.91744</td>
  <td align=right x:num="6.9119999999999999">6.912</td>
  <td align=right x:num>14.94</td>
 </tr>
  <td align=right x:num>2656.25</td>
  <td align=right x:num>23</td>
  <td align=right x:num>350</td>
  <td align=right x:num="0.93696000000000002">0.93696</td>
  <td align=right x:num="7.4240000000000004">7.424</td>
  <td align=right x:num>19.14</td>
 </tr>
  <td align=right x:num>3187.5</td>
  <td align=right x:num>21</td>
  <td align=right x:num>462.5</td>
  <td align=right x:num="9.4719999999999995">9.472</td>
  <td align=right x:num>26.64</td>
 </tr>
  <td align=right x:num>3343.75</td>
  <td align=right x:num>15</td>
  <td align=right x:num>575</td>
  <td align=right x:num="0.95648">0.95648</td>
  <td align=right x:num>12.8</td>
  <td align=right x:num>36</td>
 </tr>
  <td align=right x:num>3375</td>
  <td align=right x:num>11</td>
  <td align=right x:num>681.25</td>
  <td align=right x:num="0.97599999999999998">0.976</td>
  <td align=right x:num="14.592000000000001">14.592</td>
  <td align=right x:num>41.8</td>
 </tr>
  <td align=right x:num>3437.5</td>
  <td align=right x:num>700</td>
  <td align=right x:num="13.311999999999999">13.312</td>
  <td align=right x:num="38.826666666666704">38.82667</td>
 </tr>
  <td align=right x:num>3531.25</td>
  <td align=right x:num>12</td>
  <td align=right x:num>687.5</td>
  <td align=right x:num="39.866666666666703">39.86667</td>
 </tr>
  <td align=right x:num>3656.25</td>
  <td align=right x:num>737.5</td>
  <td align=right x:num="13.824">13.824</td>
  <td align=right x:num>50.76</td>
 </tr>
  <td align=right x:num>4593.75</td>
  <td align=right x:num>13</td>
  <td align=right x:num>1018.75</td>
  <td align=right x:num="17.408000000000001">17.408</td>
  <td align=right x:num="72.533333333333303">72.53333</td>
 </tr>
  <td align=right x:num>5093.75</td>
  <td align=right x:num>1250</td>
  <td align=right x:num="18.687999999999999">18.688</td>
  <td align=right x:num="79.813333333333304">79.81333</td>
 </tr>
  <td align=right x:num>5156.25</td>
  <td align=right x:num>1343.75</td>
  <td align=right x:num="19.456">19.456</td>
  <td align=right x:num="84.613333333333301">84.61333</td>
 </tr>
  <td align=right x:num>5250</td>
  <td align=right x:num>1425</td>
  <td align=right x:num="19.968">19.968</td>
  <td align=right x:num>88.92</td>
 </tr>
  <td align=right x:num>5375</td>
  <td align=right x:num>1481.25</td>
  <td align=right x:num>91</td>
 </tr>
  <td align=right x:num>5468.75</td>
  <td align=right x:num>1531.25</td>
  <td align=right x:num>93.08</td>
 </tr>
  <td align=right x:num>5562.5</td>
  <td align=right x:num>1562.5</td>
  <td align=right x:num="19.712">19.712</td>
  <td align=right x:num="93.426666666666705">93.42667</td>
 </tr>
  <td align=right x:num>5687.5</td>
  <td align=right x:num>14</td>
  <td align=right x:num>1575</td>
  <td align=right x:num>95.68</td>
 </tr>
  <td align=right x:num>5781.25</td>
  <td align=right x:num>1593.75</td>
  <td align=right x:num="96.506666666666703">96.50667</td>
 </tr>
  <td align=right x:num>5875</td>
  <td align=right x:num="96.773333333333298">96.77333</td>
 </tr>
  <td align=right x:num>6000</td>
  <td align=right x:num="98.293333333333294">98.29333</td>
 </tr>
  <td align=right x:num>6031.25</td>
  <td align=right x:num="18.943999999999999">18.944</td>
  <td align=right x:num="96.6933333333333">96.69333</td>
 </tr>
  <td align=right x:num>6125</td>
  <td align=right x:num>97.68</td>
 </tr>
  <td align=right x:num>6218.75</td>
  <td align=right x:num>16</td>
  <td align=right x:num>99.16</td>
 </tr>
  <td align=right x:num>6281.25</td>
  <td align=right x:num>17</td>
  <td align=right x:num="18.431999999999999">18.432</td>
  <td align=right x:num>96.96</td>
 </tr>
  <td align=right x:num>6375</td>
  <td align=right x:num>97.92</td>
 </tr>
  <td align=right x:num>6406.25</td>
  <td align=right x:num="18.175999999999998">18.176</td>
  <td align=right x:num="98.453333333333305">98.45333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="93.725490196078397">93.72549</td>
  <td align=right x:num>6468.75</td>
  <td align=right x:num>18</td>
  <td align=right x:num="98.926666666666705">98.92667</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="92.941176470588204">92.94118</td>
  <td align=right x:num>6531.25</td>
  <td align=right x:num="5.3760000000000003">5.376</td>
  <td align=right x:num>27.3</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="16.862745098039198">16.86275</td>
  <td align=right x:num>5937.5</td>
  <td align=right x:num>38</td>
  <td align=right x:num>181.25</td>
  <td align=right x:num>10.44</td>
 </tr>
  <td align=right x:num>5343.75</td>
  <td align=right x:num>35</td>
  <td align=right x:num>112.5</td>
  <td align=right x:num="7.8079999999999997E-2">0.07808</td>
  <td align=right x:num>1.28</td>
  <td align=right x:num="5.2666666666666702">5.266667</td>
 </tr>
  <td align=right x:num>4843.75</td>
  <td align=right x:num>34</td>
  <td align=right x:num="0.17568">0.17568</td>
  <td align=right x:num="4.8333333333333304">4.833333</td>
 </tr>
  <td align=right x:num>4500</td>
  <td align=right x:num="-4.9977999999999998">-4.9978</td>
  <td align=right x:num="1.792">1.792</td>
  <td align=right x:num>6.3</td>
 </tr>
  <td align=right x:num>4156.25</td>
  <td align=right x:num>33</td>
  <td align=right x:num="9.7600000000000006E-2">0.0976</td>
 </tr>
  <td align=right x:num>3906.25</td>
  <td align=right x:num>75</td>
  <td align=right x:num="5.8560000000000001E-2">0.05856</td>
  <td align=right x:num="4.1333333333333302">4.133333</td>
 </tr>
  <td align=right x:num>3875</td>
  <td align=right x:num>68.75</td>
  <td align=right x:num>4.1</td>
 </tr>
  <td align=right x:num>3812.5</td>
  <td align=right x:num="4.0333333333333297">4.033333</td>
 </tr>
  <td align=right x:num>3781.25</td>
  <td align=right x:num>62.5</td>
  <td align=right x:num="0.37087999999999999">0.37088</td>
  <td align=right x:num>4</td>
 </tr>
  <td align=right x:num>3718.75</td>
  <td align=right x:num="0.27328000000000002">0.27328</td>
  <td align=right x:num="3.9666666666666699">3.966667</td>
 </tr>
  <td align=right x:num>3687.5</td>
  <td align=right x:num>56.25</td>
  <td align=right x:num="0.56608000000000003">0.56608</td>
  <td align=right x:num>3.9</td>
 </tr>
  <td align=right x:num="0.33184000000000002">0.33184</td>
  <td align=right x:num="3.8333333333333299">3.833333</td>
 </tr>
  <td align=right x:num>3593.75</td>
  <td align=right x:num="3.6666666666666701">3.666667</td>
 </tr>
  <td align=right x:num>3406.25</td>
  <td align=right x:num="3.4666666666666699">3.466667</td>
 </tr>
  <td align=right x:num>50</td>
  <td align=right x:num="3.2333333333333298">3.233333</td>
 </tr>
  <td align=right x:num>3000</td>
  <td colspan=60 style='mso-ignore:colspan'></td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
What logger program are you using? Airflow on the 2g should be output in lbs/min and it looks like you are logging IPW? You shouldn't be able to do that with the normal logging programs.
Can you make another log, adding only airflow (lbs/min), timing, RPM, IDC (If you can) and front O2. Drop everything else so we can get the samples / second as high as possible.
Here is a new log. It didn't monitor air flow because I selected something different, but Evo Scan DOES log knock I've learned.
Code:
<head>
<link rel=File-List href="knock%20log_files/filelist.xml">
<link rel=Edit-Time-Data href="knock%20log_files/editdata.mso">
<link rel=OLE-Object-Data href="knock%20log_files/oledata.mso">
  <o:Created>2009-03-17T19:11:26Z</o:Created>
  <o:LastSaved>2009-03-17T19:11:26Z</o:LastSaved>
</xml><![endif]-->
<style>
<!--table
@page
tr
col
br
.style0
	text-align:general;
	white-space:nowrap;
	mso-rotate:0;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	border:none;
	mso-style-id:0;}
td
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
.xl24
	border:.5pt solid windowtext;}
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>EvoScanDataLog_2009.03.17_15.01</x:Name>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
       <x:ActiveRow>4</x:ActiveRow>
       <x:ActiveCol>4</x:ActiveCol>
      </x:Pane>
     </x:Panes>
   </x:ExcelWorksheet>
  <x:WindowHeight>9465</x:WindowHeight>
  <x:WindowWidth>18795</x:WindowWidth>
  <x:WindowTopX>240</x:WindowTopX>
  <x:WindowTopY>270</x:WindowTopY>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<table x:str border=0 cellpadding=0 cellspacing=0 width=516 style='border-collapse:
 collapse;table-layout:fixed;width:389pt'>
 <col width=64 span=2 style='width:48pt'>
 <col width=118 style='mso-width-source:userset;mso-width-alt:4315;width:89pt'>
 <col width=82 style='mso-width-source:userset;mso-width-alt:2998;width:62pt'>
 <col width=102 style='mso-width-source:userset;mso-width-alt:3730;width:77pt'>
 <col width=86 style='mso-width-source:userset;mso-width-alt:3145;width:65pt'>
  <td width=118 style='width:89pt'>TimingAdv</td>
  <td width=82 style='width:62pt'>O2Sensor</td>
  <td width=102 style='width:77pt'>InjDutyCycle</td>
  <td width=86 style='width:65pt'>KnockSum</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="88.235294117647101">88.23529</td>
  <td align=right x:num>2781.25</td>
  <td align=right x:num>7</td>
  <td align=right x:num="28.213333333333299">28.21333333</td>
  <td align=right x:num>1</td>
 </tr>
  <td height=17 class=xl24 align=right style='height:12.75pt'
  <td class=xl24 align=right style='border-left:none' x:num>2937.5</td>
  <td class=xl24 align=right style='border-left:none' x:num>10</td>
  <td class=xl24 align=right style='border-left:none' x:num="32.3333333333333">32.33333333</td>
  <td class=xl24 align=right style='border-left:none' x:num>1</td>
 </tr>
  <td height=17 class=xl24 align=right style='height:12.75pt;border-top:none'
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3187.5</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>11</td>
  x:num="37.6666666666667">37.66666667</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>1</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3687.5</td>
  x:num="42.293333333333301">42.29333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3656.25</td>
  x:num="40.9866666666667">40.98666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>12</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>39.78</td>
 </tr>
  x:num="40.906666666666702">40.90666667</td>
 </tr>
  x:num="41.253333333333302">41.25333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3750</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>42.4</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3781.25</td>
  x:num="45.226666666666702">45.22666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4281.25</td>
  x:num="57.613333333333301">57.61333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4906.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>14</td>
  x:num="72.106666666666698">72.10666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5281.25</td>
  x:num="0.99551999999999996">0.99552</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>80.04</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5406.25</td>
  x:num="81.6666666666667">81.66666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5500</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>84.96</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5531.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>13</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>87.6</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5625</td>
  x:num="89.786666666666704">89.78666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5718.75</td>
  x:num="90.773333333333298">90.77333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5781.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>93</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5875</td>
  x:num="92.746666666666698">92.74666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5906.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>15</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>93.24</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5968.75</td>
  x:num="93.926666666666705">93.92666667</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6062.5</td>
  x:num="94.413333333333298">94.41333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6093.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>16</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>94.08</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6156.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>95.04</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6187.5</td>
  x:num="94.1933333333333">94.19333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6250</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>17</td>
  x:num="95.613333333333301">95.61333333</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6312.5</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6343.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>96.56</td>
 </tr>
  <td width=118 style='width:89pt'></td>
  <td width=82 style='width:62pt'></td>
  <td width=102 style='width:77pt'></td>
  <td width=86 style='width:65pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
Looks good. Your IDC's are getting up there, so you might want to consider some larger injectors. But, you have a good timing curve and what looks like no knock. I see it shows 1 count the entire way through the pull, so I'm going to assume that's normal for the EVOScan program.
As Tyler said, I would lean things out. If you had larger injectors, you could up the boost. But if you do that, your IDC's would need to go up to compensate for the additional airflow, so going leaner is your only option.
Ya I've been noticing that too. I think if I rewire the 190 I'll push some more fuel out, plus I have a small boost leak I need to fix. I'm not gonna lean it out anymore until I get a wideband o2, and egt gauge. I'm runnin 550s, I wouldn't think they would go that high, but I'm running 18 psi on my 14b.
Thanks for all the help everyone!!! :thumb: When I get the gauges I'll tune it more, and post up another log. Then I can get my evo 16g, and save my pennies for dsm link. :rocks:
Something to note, if you're logging with EvoScan in Mitsubishi mode on a DSM ecu, you will have to change the addresses for the data you are logging.
I don't know all the specifics, but I do know that the knock sensor data for one is incorrect in your log.
You need to double check what you're logging before going any further.
Have you seen Ceddy's new free datalogger, MHIScan?
Works on 97+ DSMs right now with 95-96 support coming later.
Why does this page look so F'ed up?
Code:
<head>
</xml><![endif]-->
<style>
<!--table
@page
tr
col
br
.style0
	text-align:general;
	white-space:nowrap;
	mso-rotate:0;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	border:none;
	mso-style-id:0;}
td
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
      </x:Pane>
     </x:Panes>
   </x:ExcelWorksheet>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 </tr>
 <![endif]>
</table>
</body>
</html>
Can you please tell me how you posted your evoscan log? I have been trying to figure it out so I can post mine.
X2 on this thread being jacked up size wise.
97% TPS value is fine and the ECU will enter open loop at that value.
Don't trust the TPS value on the SAFC, as it's incorrect. The SAFC looks at the minimum and maximum voltage from the TPS sensor and assumes that the minimum voltage corresponds to a TPS value of 0% and the maximum voltage corresponds to a value of 100%. So, your TPS could be way out of whack and the SAFC will report it as 100%.
Here is my newest log, I believe I am logging knock correctly now, I had to change some settings in EVO SCAN. I am logging airflow in HZ.
Code:
<head>
<link rel=File-List href="3-24-09%20LOG_files/filelist.xml">
<link rel=Edit-Time-Data href="3-24-09%20LOG_files/editdata.mso">
<link rel=OLE-Object-Data href="3-24-09%20LOG_files/oledata.mso">
  <o:Author> </o:Author>
  <o:Created>2009-03-24T15:49:58Z</o:Created>
  <o:LastSaved>2009-03-24T15:54:41Z</o:LastSaved>
</xml><![endif]-->
<style>
<!--table
@page
tr
col
br
.style0
	text-align:general;
	white-space:nowrap;
	mso-rotate:0;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	border:none;
	mso-style-id:0;}
td
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
.xl24
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>Sheet1</x:Name>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
       <x:ActiveRow>27</x:ActiveRow>
      </x:Pane>
     </x:Panes>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet2</x:Name>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet3</x:Name>
   </x:ExcelWorksheet>
  <x:WindowWidth>14955</x:WindowWidth>
  <x:WindowTopX>720</x:WindowTopX>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<table x:str border=0 cellpadding=0 cellspacing=0 width=430 style='border-collapse:
 collapse;table-layout:fixed;width:323pt'>
 <col width=64 span=3 style='width:48pt'>
 <col width=110 style='mso-width-source:userset;mso-width-alt:4022;width:83pt'>
  <td height=17 class=xl24 width=64 style='height:12.75pt;width:48pt'>TPS</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>RPM</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>KNOCK</td>
  <td class=xl24 width=110 style='border-left:none;width:83pt'>AIR FLOW HZ</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>TIMING</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>O2</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>2843.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>0</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>475</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3343.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>687.5</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>9</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3968.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>850</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>3937.5</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>10</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4000</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>887.5</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4031.25</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>931.25</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4218.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>1050</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>4937.5</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>1337.5</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>1581.25</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>5937.5</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>1593.75</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6031.25</td>
 </tr>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6218.75</td>
 </tr>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6375</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6468.75</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6531.25</td>
 </tr>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>6593.75</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>18</td>
 </tr>
  <td width=110 style='width:83pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
