Omg Im In Loveeeeee Wooohooooo!!!!
I hope this guy comes through on my car :| so i can be rollin this
Holy dark pictures, Batman!
Originally posted by top_end95
:cough:7 bolt :cough:
Should of gotten a 1G AWD :cool:
Just kiddin'. :D Enjoy!
it walked at 175,000 miles already and he replaced everything with upgraded stuff heres the list hold on :
New crankshaft, pistons, rings, connecting rods with arp rod studs, bearings, balance shaft eliminator kit, oil pump, water pump, timing belt, timing belt tensioner, tensioner pulley, idler pulley, head bolts, head gasket, valve seals, spark plugs and air filter along with all new seals and gaskets throughout the motor. Machine work includes: Bored cylinders, decked block, cleaned block, balanced crank, rods, pistons, harmonic balancer and flywheel. Flywheel was resurfaced. Head was cut and received a 3 angle valve job with new seals. Transmission has new axle shaft seals along with new cv boots and a BRAND NEW Transfer case all complimented by a new clutch.
The only negative points on the car are the typical pitting of the mitsu stock wheels and there is a small scratch under the gas door about 2 inches in length.
so i hope it will make me happy LOL it did yesterday
:thumb:
