viprez586
- 1,006
- 23
- Aug 10, 2006
New Berlin,
Wisconsin
Okay, I've searched but need to know some answers from some wisemen.
Background: Bought engine from Karking and after break in had unusually low compression (125psi across the board). Couple months ago the engine overheated and warped the head so now I'm rebuilding it.
I'm going to be running .020" over-sized pistons, they are stock replacements made by rock pistons. I plan on running a E316G and ideally shooting for 300-350hp. I've been really good with keeping my coolant temperatures in check (203-206*F at all times). That's why you never let someone else drive your car.
Problem is Kar King, in their infinite wisdom gave me a N/T block with turbo accessories. It also has the balance shafts removed so i know this equals really high oil pressure.
Machining the block to accept the squirters is probably going to be ridiculously expensive.
Here are my ideas to combat the issue:
I'm curious if this is why I've been having problems with low compression in the first place - thus not cooling the pistons enough and frying the rings in the process.
I guess my question here is what can I do on the budget side of things, or is the risk to great and should i either find a turbo block, or have them machine my n/t block to accept the squirters.
- Run External oil cooler with a fan to operate at all times(once up to operating temp of course) to keep the oil as cool as possible.
- Port oil filter housing relief valve mod
- Port cylinder head mod #1
