oil pump and trigger plate differences
ajpm26
168
Jun 22, 2010
Niles, Illinois
Before you guys tell me to search, I already did.
I know the 1g 7 bolt and 2g oil pumps are the same, but do they have the same timing mark location? Or does the 1g 7 bolt have the timing mark in the same location as a 6 bolt?
I can't seem to find anyone to know nor care to find out if they're the same or not. The reason I ask is because I have two trigger plates, one from a 1g, and one from a 2g. The one from the 1g is from a 6 bolt but according to a vendor the 1g's(6 and 7 bolt) had the same trigger plates. When you look at the two(1g and 2g trigger plates), the location for the timing mark is different on each one.
I just want to make sure I use the correct one for my 1g 7 bolt.
Thanks
There are 3 different options for plates. There is the 6 bolt plate, the 1g 7 bolt plate and the 2g plate. The 1g 7 bolt and 2g have the same timing mark, the only difference is that the 1g 7 bolt plate is round and the 2g plate has the triggers on it.
