2G OBD II scanners that work
Marino2g
Aug 13, 2023
Mostar, Europe
Hello guys would like a little help because I can't seem to find a place that has a diagnostic tool for my 2g that works.
I'm from a small country in Europe that only has 3 2g eclipses in the whole country. I went to a mechanic shop that has a universal OBD scanner it loads up and when you select the make, model, engine, year and so on it can't load the car like it isn't even hooked up.
I have a n/a 4g63 7 bolt motor in my 2g. I also don't have the white connector that is right next to the OBD II port I'm not sure if that is mandatory to have or maybe it isn't working because of that.The check engine light just came on recently.
Help is much appreciated!
  • Wanted 6 bolt NT water pipe
    • chrisman287
