O2 wire routing question?
genegoesfast
559
3
Dec 3, 2010
Nashville, Tennessee
I want to hide the wiring for my wiring for my o2 sensor. I found a good spot along the water pipe against the block. My question is, is this location going to destroy the wiring? I've included a pic of the sheath around the wiring. I believe it to be heat wrap. Let me know what you think.
You should be fine along that water pipe on the block. After all, it's not near as hot as the way the factory routes it over the top of the exhaust manifold heat shield. That's why it has that wrap around it... So it can survive on the top of the exhaust manifold. But, anyway... You'll be fine with putting it there. Good luck with the car.:thumb:
Cool, I hope you're right. I didn't own this car when the o2 was routed in a stock fashion. Plus, the wiring will be be 4 inches or so from the hot side of the turbo while sitting on that water pipe.
