o2 Housing to Downpipe Stud
Are you just cleaning up the threads or did you have to drill it out? If you drilled it out, you'll need to tap it out to a larger size, get a larger stud and nut, and maybe have to drill the DP hole if the stud won't fit through.
Yeah I knew the stud size, just was wondering if anyone knew off hand the tap size so I didn't have to do all that, but I can do that anyway. Thanks tho! :thumb:
Unless I'm misunderstanding you, the tap size is going to be the same as whatever stud you will be using.
But if the threads have been damaged you could do as kenamond suggested or helicoil it allowing you to retain the stock stud size.
