Not enough pressure?
BLKGSX23
91
May 1, 2009
Sullivan, Missouri
Ok, well I swapped my buddies injectors for him. was running 680's and one was messed up causing the car to run like shit. Swapped in some FIC 1050's and the car barely wants to start. Got on link and set the global to -60 and deadtime 330 like they call for! Pulled the fuel rail and turned over the car and they are spraying but barely spraying any gas at all, like they dont have enough pressure! Base Fuel Pressure is set at 40! And the wideband is reading really lean which would be the reason why the injectors are barely spraying shit! Any idea guys? Need to figure this out very soon!
Thanks, Ryan
could possibly be a clogged fuel filter that is restricting the flow. dont see why it wouldnt have done it before you put the new injectors in but you never know.
take the vaccum line off of the fuel pressure regulator and look for any gas that is in the nipple or line. blow in it to see if it holds. any gas in it its bad or if it doesnt hold pressure its bad.
