eclipsegsx1736
Supporting VIP
- 1,599
- 44
- Nov 11, 2003
Los Angeles,
California
I installed coilovers, I have it set at close to a 1.5" drop all around. I did the rear camber longer bolt and spacer mod which helped alot visually. I got an alignment today and the rear was 1.3 degrees on both sides. We got the toe to 0 all around. The front camber on the driver side was 1.5, and the passenger side was 2.3...I read on here that the passenger camber is always higher for whatever reason. I'm planning on tracking the car soon on a road course, after I get a rear swaybar and I think I actually need more front camber. I'm already using 6 washers in the rear to bring it to 1.3, but they're not that thick. Is it safe to go with 8 washers if the bolts are long enough? Im kinda hoping for a rear camber of .75 and a front camber of 2-2.25..Will I need a camber kit (Ingalls or similiar) for the front or is there another way to gain some front camber? All I see is people trying to decrease front camber after lowering.
