Non-ABS - In Search for Part #
SanTa_
224
Jan 25, 2007
Methuen, Massachusetts
I've called a few dealerships looking for
Part #:MB895894
Item: Front right brake tube
With no luck at all, as they have said it has been discontinued.
I don't mind running a SS line to it, but I rather keep everything in the appearance department the same.
So if you're selling a used one, or know where I can get it please reply in this thread with either contact information or I'll send you a PM.
I'll be doing some online searching, but I'm at school at the moment so I thought I would throw this up real quick.
Probably a online vendor - JNZTuning & DSMGraveyard have been called.
I ordered all the other parts. Just this part will be needed.
I know I can also buy straight brake lining from an auto parts store..
Are you looking for just the rubber hose part or the whole brake line? If its just the line I would just goto the auto store and get a new line with new fittings. They come in different sizes and VERY easy to work with
Yeah it's the line itself.. from the prop valve to the front brake along the firewall.
That's why I mentioned that I knew I could go to a auto part store and do it myself. *shrugs*
If it comes down to me not able to find it then I'll do that as a last resort. ^.^
Id go with SS goodridge brakelines you can get a full kit for all your brakes for around $90-130 depending on the vednor/sale but i was in that same dillema with my rear calipers for my 90 tsi awd i called mitsubishi and they said there was only 1 left in the whole country so after that ive decided to go all aftermarket on everything other than stuff i need to be mitsu like banjo gaskets/shifter cables etc.. but yeah you cant beat a lifetime warranty on brake lines from goodridge just my .2 :thumb:
That's actually a better option since working with the prebent lines is very rough to do.
Negative..no luck. I tried using the part number and browsed through.. :[
I only got the site link, not a direct link to the item. =[
EDIT: I manage to get it..only thing is I wonder if they have it. JNZTuning had to item listed up, so I added it to my cart, but when I called them they said they don't.
They'll have it - I get all my hard to find oem parts through them - when they have stuff like internal tranny input shaft shim spacers (which I haven't been able to even order through Mitsu dealers here), they certainly will have that. They are a Mitsu dealer which sells real factory oem parts.
At the link, put MB895894 into the "Search by Part Number or Keyword" space, select Make of Mitsubishi, and click search. Click Contact Us for phone # or email if you want to double check availability or talk to them.
When you know the oem part # it's always there even though sometimes it doesn't show up when browsing.
