noise coming from back tire???
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i am hearing this noise coming from my back tire driver side it only happens when i first drive the car and only lasts for 10-20 sec i thought it was brakes/rotors but i just chnaged both and still happens, its like something is rubbing, can anyone help!!
Did you check your hub, strut mount, or dustshield? I had the same problem just found out today that it was my rotor.
Possible Failed wheel bearing.
jack the rear up rove the wheel and inspect the rotors, wheel bearing and half shaft for play and rubbing.
Good luck.
  • Wanted 6 bolt NT water pipe
    • chrisman287
