no tach signal
coltkelz
78
Dec 8, 2010
winnipeg, MB, Canada
ok guys i am having issues getting a tach signal to hook up my new tach to i dont get a signal at the pt the ecu or the gauges... im stumped completely this is a 92 tsi motor
ok guys i finally reciever my ner t i installed it and im getting a signal but its not right. im using a EQUUS 3-3/8-in. Black Tachometer #34-0100-2 and it seems to sit at about 500 but redlines at 3000. i believe i need an adapter but im not sure of what to use.
It's reading half of what it should. If you hooked it up to the PT (power transistor) white wire, then either the PT is bad (it's interior NOR gate) or you are only firing on 2 cylinders (so tach is reading correct).
