dsmdriverjeff
- 0
- Nov 22, 2012
Puyallup,
Washington
okay so I have been having problems with my car and I thought they were over but clearly not, I had another post about this http://www.dsmtuners.com/forums/pac...sm/452183-no-spark-1st-4th.html#post153149305
So basically one night when I was driving home my car died come to find out my timing belt was missing teeth so it bent valves and my serpentine belt also broke, long story short I went through my whole car trying to figure out why it wouldn't start after I rebuilt the head, new parts include:
-ecu
-ignition control module
-ignition coil
-spark plugs
-camshaft postion sensor
-crankshaft position sensor
-alternator
-all of the belts
-battery
-and I also took out the stock air intake box and switched it with a filter
I am totally confused on why it is not starting now, when I turn the key it cranks and cranks and cranks and cranks and it almost starts up but it wont it just sputters a couple times and keeps cranking, I pulled the spark plugs and they were soaked in gas so I dried them off and I read something about holding the gas pedal to the floor while cranking will help get the car started, and it DID!!! but the problem is it'll only stay running if i'm holding the gas down, the moment I let off the gas it sputters out and dies, please someone help me I need this car for the winter time in the snow and its been dead for a year now just sitting!!! any ideas are appreciated!! thanks
-ecu
-ignition coil
-spark plugs
-alternator
-all of the belts
-battery
how do I make this post more public so more people read it?
