ZIO
- 0
- May 10, 2012
Seattle,
Washington
no fuel pump noise, no ecu light when key engaged (does the 1990 GST have a ecu light?)
mst relay clicks to on before starting
no voltage on fuel pump check point in engine bay which confirms no fuel.
car turns over but doesn't start and no smell of gas
had ecu repaired with new caps because of leaky faulty ones, foil looks ok, all chips look ok, all other things on the board look ok.
everything else sees to work, lights, etc, it just won't start.
my manufacture date says sept 1990, the ECU is a MD 128625
need help!
need help!
