classic69
- 48
- 0
- Mar 30, 2005
Binghamton,
New York
im having a no spark problem on my 1990 Eagle Talon AWD 5speed. i tested the ignition coil and ignition module both are good, seems to be getting no signal from ECU, i have a 1992 Eagle Talon AWD AUTO ECU that i use in my other DSM, would that ECU start up the '90 car? i read the compatibility list but it only mentions a different tach setup or something, also how do you test the ignition signal on an ecu, i think its pins 55 and 54? all help is appreciated thanks
