no spark in my n/t to turbo conversion
fasteclipse1992
786
Jan 17, 2003
joplin, Missouri
i did a complete 1.8 to 2.0 turbo swap, i changed over every thing from my turbo talon to my 1.8 eclipse from the ecu, wiring harness, fuel pump exhaust,everything. car cranks over but it isnt getting any spark at all. i changed the caps in my ecu because 1 leaked. got my coil pack tested and was told it was in tolerance. i hooked up every connector to the proper place i dont know what i could of missed that could keep me from getting a spark. its getting fuel and air but nothing to ignite the mixture. help is needed badly i need this car running by sunday night for work on monday morning.
If your caps leaked, it might have done too much damage to the board to be useable again. Try swapping in another ECU from another turbo model.
thats what im tryin to do if i can find a seller on this site who has 1 to sell. i noticed u did a turbo swap also did u run into any probs? and do u know what the white 2.5" x1/2" connector that is with the 3 yellow ecu connectors is for on the wiring harness?
