No Reverse after IPT Translab kit install.
dfgu
Aug 3, 2004
ny, New York
So after I put in the translab kit. I have no reverse. I had reverse before I put the kit in. Everything was working fine before I put the kit in. But in Drive, after the kit, it does feel a lot better. But for some reason, I cannot for the life of me figure out why I dont have reverse. I have to take out the valve body to inspect it again anyways, so I was wondering if there is anything I should look out for that would engage/disengage reverse?
I called IPT, and the first thing they told me to look for was that rubber O-ring on the valve body. I'm most certain that I put it back on. So is there anything else I could look for specifically?
Thanks!!!
This is for a 1G tsi awd..
Update: I just took apart the Whole VB again to check everything.. and everything is where it should be... Do you guys think it could be the solenoids?
If it was the solenoids you wouldn't have second either since solenoid A is off and B is on for both of them. Did you take the valve body apart again to make sure the shift kit is in right. And double check the torque on all the bolts.
