no pressure in clutch pedal
toms99
Sep 6, 2006
florence, Kentucky
Ok i am driving along last night and the pressure in my clutch pedel is gone. i raise the hood and no fluid. so i refill it. no big deal. just to be safe i look under the car and i am leaking clutch fliud from a broken line. I buy a new line install it bleed the clutch retighten everything a go on. My question is should i do anything else to the system or to the slave.
Nope, if all you did was broke the line than that should be it. You might want to check the condition of your motor mounts. If they are worn the engine will rock back and forth and this can lead to breaking clutch lines. Atleast in my case anyway.
As long has it is blead correctly and enough that should be all. Check your pedel and make sure there is a tiny bit of play before it catches at the bottom of the throw. You dont want to be burning up your clutch when you have it all the way pushed it:thumb:
thanks for the adivse i will do that
checked the pedel catches just right thanks for the advise
