No power with cold engine.
Chris_Sag
102
Sep 8, 2010
Bergen, Florida
Hi. When my engine is cold and its cold outside it runs badly, it has no power at all. I know that you dont push a cold engine, but im having problems reaching 60kmh. When the engine is hot it runs like a dream... Why?
the temp sending unit sends a signal to the ecu . the ecu is programed to run at different engine temps by adjusting air fuel ratio.
Check your vacuum lines, including if you have a boost controller...check and make sure the lines aren't hooked up backwards.
