No more cat?!!
shaggman1
Sep 30, 2004
Kansas City, Kansas
I am going to be replacing my stock down pipe and cat with a solid piece that will eliminate the cat. I will be putting the O2 sensor back in right about where it was to begin with. Should I expect to get a code from the ECU with this change? The pipe I found is made by "Authority". I found it at Importboost.com for $165.00. SS mandrel bent. Seems like a Ok deal to me.
Thanks,
Rick
i dunno about 92's but my 90 is on the o2 housing...not the downpipe...so if you are getting a 02 eliminator then there should be a bung welded in already...just screw it in...
Thanks guys, that will be a big help. If I do get a code then I know how to get rid of it.
