no hose on waste gate
I-luv-em-all
602
5
May 25, 2004
Regina,
my friend bought a 2g gst off ebay, he brought it by my work and of couse i told him to pop the hood i looked at it and it had stock turbo stock everything other than a open k&n, when i looked at the waste gate their is no hose at all on the wg, i dont know how it gets any signal or how it is working, he has an aftermarket boost gauge and he says it runs 14psi any one have any comments or concerns.......?
psychlow said:
Wow. Well, maybe he has a huge boost leak?
Sure he doesn't have an external wastegate?
There's a huge boost leak alright -- it's called the 2g BOV. About 14 psi is the max I could get with a MBC get until installed a 1g BOV. My first test with the 1g BOV installed almost pegged my boost meter. OMG
Wow, I bet you're right.
Pressurize the intake to 17PSI or so and check for leaks. If it's the BOV, get that sucker replaced with a 1G unit and hook the wastegate actuator back up to a boost source.
JoeWagon said:
I think you would run WGA spring pressure with an open nipple. 7 psi.
Huh? :confused:
Unless you put boost pressure on the WGA spring, the WG arm will never move. If the nipple isn't sourced to anything, that wastegate's staying closed no matter how much boost you build.
psychlow said:
Huh? :confused:
so that means max boost of the turbo right? So pow to the turbo?
That'd be my guess, especially considering with a boost leak, there's not even as much resistance on the compressor wheel to slow down the wheels. So you're going to run the turbo at insane speeds - speeds that the turbo bearing wasn't designed to handle.
great way to having a reason to upgrade turbo's :p
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
