no fuel pressure
highgrindr
Jul 6, 2003
i am working on a 1997 eclipse gs, used to start and run... then turned to accasional starting, and now its not starting at all.... i dont hear the fuel pump buzz when i turn the key, and when i relieve the fuel pressure on the fuel rail, little to no fuel comes out, so that is why it isnt starting.... what do i do to go about finding where te problem is.... please help.... :)
I think you just solved it yourself, you said you dont hear the fuel pump "buzz", and there is little pressure in the system, sounds like you need a new fuel pump maybe?
yeha, but where is the fuel pump relay on a 2g n/a? what weould cause the fuel pump to not come on... i also get a code 12 for the keydance....
