ECUflash No connection. Everything is working(I think)
98turbo
296
11
Aug 22, 2004
Mobile, Alabama
I'm running Windows 10. I have experience with ecuflash prior to this with a shop I used to work at. I've uninstalled and reinstalled the software and drivers multiple times. I've moved the usb around to different ports, I've tried turning the ignition on exactly when I hit initialize, nothing. It will not connect. I've also checked the OBD2 port with a code reader, it worked for that. Any other suggestions? I'm happy to try anything.
You need to install the driver before you ever plug the cable in for the first time, if you didn't you might have a mess.
[19:56:42.904] using metadata XML ID read_evo5 from file C:/Users/adaml/Desktop/EcuFlash/rommetadata/read templates/read_evo5.xml
[19:56:42.911] FTDI Driver Version 2.12.12
[19:56:42.924] Using interface OpenPort 1.3 Universal TX2NmCuoc6484cdd5e6babb3ec3a82c58ab2a754405e5156
[19:56:47.345] sending init sequence 2
[19:56:47.355] got 0x11 response
[19:56:47.355] sending init sequence 3
[19:56:47.731] entering bootloader
[19:56:47.732] sending kernel size (2029)
[19:56:47.753] sending kernel load address (0x0000F000)
[19:56:47.773] uploading kernel
[19:56:48.100] verifying kernel checksum response
[19:56:48.110] kernel valid
[19:56:48.314] kernel get version
[19:56:48.335] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.07
[19:56:48.335] reading kernel comm buffer size
[19:56:48.343] comm buffer size set to 256
[19:56:48.343] reading kernel flash buffer size
[19:56:48.355] flash buffer size set to 1024
[19:56:48.366] interface close
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
