No blower motor or rear defroster
white95tsi
30
Aug 17, 2003
Just recently I installed an apexi tt, and since then I have no blower motor or rear defroster. I know the relays for both are right under the hood latch. Is it possible that I knocked a wire off or something, and if so do you know which wire I should look at. I really dont want to go to the dealer and order new relays if thats not the problem. Let me know if anyone has had a similar problem.
Also on a sidenote, the apexi tt has a white wire coming off the harness, that I have no idea where it goes. The tt doesn't stay on unless my ebrake is in the up position, so in order for it to work I have to turn off the car, put it in neutral, pull the ebrake and set the timer, and it works fine. I'm thinking this is bc of the the white wire but I dont know. Let me know if you have any ideas.
