For Sale New Year New List!!!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
All parts are located in Morgantown WV - as always feel free to txt or message me for more information! Dont see it ask--- I have 1000's of parts here not listed!
photos shipping and payment options can all be found on rixracing.com
Lightly used Greddy Kevlar timing belt 55
TurboXS Boost Controller 45
Autometer 5” Tach with shift light 45
Blitz Full Auto Turbo Timer with 1g pnp harness 35
Vibrant Racing Vacuum block 20
Fluidamper Crank Pulley 235
Brand new Dejon Tool Non recirc intake pipe 155
1g dsm Speed Density Harness 50
Omni 4 Bar Map Sensor 50
Avid Racing Tuner Series 1g dsm Engine Mounts 225
Fuel Lab AFPR 125
PTE Low-z 1600cc Fuel Injectors 265
Freshly Rebuilt and powdercoated gold EVO REAR Brakes 400
EVO Front and Rear brakes with adapters for 2g DSM 675
ECMLink V3 Full with ECU for 2g DSM 625
Black AEM Fuel Rail 100
Fuel Lab AFPR - Purple 130
PTE 1000cc Injectors 225
Jacks "2.2 "Heavy Duty" 2g AWD Transmission 1850
VTEC This Spark plug cover 50
2g BC Coilovers 675
Throttle Body 90mm to DSM Style adapter 35
Magnus V3 Intake Manifold (1g head flanged) 825
JMFab Top Mount open T4 Exhaust manifold 950
PTE 6466 Gen-2 DBB T4 Turbocharger 1750
Kinectic/SBR 2g "short route" FMIC Core 350
Brand new Tial 38mm MVS Wastegate - Purple 235
Brand New in box Tial 50mm BOV (Purple) 220
4 bolt manual rear diff w/ axles and cups 325
Quartermaster Twin Disc Clutch - 6 Bolt AWD 675
Fidanza Cam Gears - Blue 140
Cleaned and tested 880 CC PTE Injectors 185
Blue AEM Oil Cap 35
AEM Adjustable Fuel pressure Regulator 130
HKS EVC EZ2 Boost Controller 225
AEM 50 PSI Boost Gauge 125
JMFab Twin Scroll T3 Mani w/ 7 Blade Hx40 Combo 1650
JMFab "Race" Sheet Metal Intake Manifold - for 1g head 400
COP Setup with MSD DIS-2 Ignition setup for a 1990 DSM 450
FP3 Cams - DSM 400
Built 1g head - Kiggly springs/retainers SS Valves, Ported and polished 800
Built 6 bolt shortblock - Eagle Rods Wiseco Pistons 1800
1995 Eagle Talon TSI Automatic 4500
Rexspeed Carbon Arm Rest 100
Throttle Body FIAV Block-Off plate 20
2g Manual Speed Sensor 35
2g Auto Speed Sensor 30
Old school turbonetics wastegate 40
Genuine Greddy Type RS Bov 90
Braille Small Battery tray 65
Innovative Digital Boost Gauge 100
Air horn kit! 50
Dejon 3” intake pipe 85
Black top 1g CAS 85
7 bolt forward facing oil filter housing 50
1990 style bolt oil filter housing 45
6 bolt oil filter housing 40
6 bolt oil pan 50
J pipe for 14b 16g turbos 20
Refreshed Holset Super HX40 with Billet Wheel 775
Refreshed FP Super 99 in T3 .85 Housing! 1050
2g GST Fuel Sender 40
Shurflo Methanol Pump 40
Gold Spark Plug Cover 20
EVO 8 \ 9 Aluminum Underdrive Crank Pulley 40
2g Dash Surround Dual Gauge Bezel 20
MSD Digital Window Switch 65
Greddy Turbo Timer 25
HKS Turbo Timer 35
TurboXS Quad Stage Boost Controller 150
2G TCU 50
2G Exhaust Manifold 50
EVO Spark Plug Cover 25
OEM DSM Spark Plug Cover 35
EVO 8 / 9 Exhaust Manifold 75
Onsoku DSM Cam Gears 85
DsmChips 2g Eprom 40
1991-1994 cluster 45
2g dejon tool long route upper intercooler pipe 100
2g black airbag 75
Evo 8 steering wheel has wear on top 200
Evo 8 front floor mats 65
Front passenger side fender evo 8 9 150
83k mile 1990 DSM Cluster 100
EVO 5 speed shifter base and cables 150
EVO 8 / 9 Carbon fiber dash inlay 125
2g megan racing shifter with base 100
2g shifter and shift cables 125
2g awd rear trailing arms with red urethane bushing 65
New 2g front control arms with red urethane bushings 85
Oem evo 8 rear bumper 200
Yellow evo 8 9 trunk lid with spoiler 300
Black evo 8 9 trunk lid has holes for spoiler 200
EVO SSL Amp and Subwoofer 200
RM Front and Rear AWD Dsm Swaybars 300
Yellow driver side fender 200
Red Magnus Fuel Rail -10an fittings 100
Straight line Specialties Open T3 Exhaust Manifold 650
Tial F38 2 bolt wastegate 130
Coil on Plug setup with 300m coils 225
ACT 2600 clutch cover 125
AEM 5 Bar Map Sensor 80
Healthy 2g Knock Sensor 50
EVO 8 Blue Cloth interior - Fair Shape 300
EVO 8 / 9 Dashboard w/ Passenger side airbag 150
EVO 8 / 9 Rear Axle Pair - Only 24,500 Miles 400
Evo 8 / 9 Rear Differential - only 24,500 original miles! 800
Buschur Double Pumper with 2 255 Walbro Pumps and rewire kit - EVO 8 / 9 400
EVO 8 / 9 Cusco Rear Sway Bar (25mm) 200
EVO Brembo Brakes - Fronts and rears 525
Used Working ACD Pump 350
EVO 8 / 9 Exedy Twin Disc - Needs Rebuilt 200
EVO 8 HKS 264/272 Cams 325
EVO 8 HKS 264/264 Cams 325
Innovate LC1/LC2 Wideband Kit 130
AEM Wideband Kit 125
Brand New OEM Mitsubishi MLS Head Gasket for DSM 120
VERY LIGHTLY USED OEM "Nylon Reinforced" Timing Belt 55
Used Gates Kevlar Timing Belt "Blue" 50
2g Tokiko Blue Struts with tokiko red springs 250
2g Tokiko Illumina Adjustable Struts with Tokiko Red Springs 400
Standard 6 bolt ARP Head Studs 50
1g non abs front lines and prop valve 85
2g non abs front lines and prop valve 85
23 Spline 91-96 Manual Transfer case 150
2g FWD 5 Speed manual Transmission 350
FIC "EasyTune" Box 325
2g Manual NON LSD rear diff 200
2g Manual LSD Rear Diff 225
Oem EVO 8 Tail lights 200
Evo 8 valve cover 200
2g gauge cluster 65
ACT 2100 Pressure Plate 125
2g throttle body with sensors 65
1g throttle body with sensors 70
ECMLink v3 GM Maf wire 50
Unorthodox Racing Aluminum Crank Pulley 40
VERY LOW Mileage NON-ACD Transfer Case - EVO 8 and 9 1400
22 Spline Manual Transfer Case 150
Genuine MHI Small 16g turbo 500
Good Used Saturn Alternator 50
Blox Evo 8/9 front rollstop 50
1g Water Neck / Thermostat Housing 35
1990 Specific Green Top CAS 40
XSPower Ebay T3 Exhaust Manifold and Wastegate 40
2g Alternator 40
A1 Technologies 6 bolt head studs 190
6 bolt water pipe - heater core deleted 65
1995 Mitsubishi Eclipse GSX Roller 850
1995 Mitsubishi Eclipse GST(AWD converted) 800
45k mile 1g auto chassis 2000
EVO Roller No title LOW Miles No Rust 1800
90-96 Manual Halfshaft 75
Jay Racing 1g Alternator Relocation Kit 105
Carbon Fiber EVO Armrest Cover 100
6 bolt water pipe with -16an welded fitting - illusion purple 45
Ramhorn T3 Exhaust Manifold 225
FIC 750cc Hi-Z Injectors 325
ID 725cc Hi-z Injectors 325
DSM 450cc Injectors 90
EVO 9 GSC S2 cams 400
Bulfab 1G auto front cross bar 100
2.5 inch upper intercooler pipe with tial flange 125
1g Knock Sensor in Excellent shape 50
Good 1995-1996 MPI relay 25
CRACKED! Valve cover with -10 an fittings 100
1g Green top CAS 35
Polished valve cover with -12 weld in vent 225
Walbro 255 fuel pump 35
Sheepy 850 HP Intercooler core 425
EVO 7 Tail Lights - Stanley 375
Dsm power transistor ptu 35
Comp Turbochargers Billet 6765 T3 Journal Bearing Turbo setup 700
Brand new BSFab 3" Vband Downpipe 450
Kiggly 6 bolt Flexplate 100
AFCO Dual Pass aluminum Radiator 325
1g JMFab Small Battery Kit w/ Oddessey PC680 Battery 240
Fuel Lab "Prodigy" Fuel Pump 475
Precision 6766 Turbocharger - .82 AR T3 Turbocharger (Journal bearing) 885
Very low mileage Built 6 bolt short block with Arias/Manley Turbo Tuff combo 2400
Dynarc Fab catch can for 2g DSM - 8an Fittings 200
Black Tial MVS 38mm Vband wastegate with clamp 235
S90 70mm Throttle Body 200
2g "Euro" Tail lights 325
ARP 'L19' Head Studs for a 7 bolt 200
Brand New Precision 6870 .96AR Vband turbo 1900
Automatic Transfer Case - 91-96 Ratio 200
2g Automatic LSD Rear Differential 225
2g Precision Torque Converter 750
3g - Revised "No Tick" Lifters 65
Remote Tuning - 'Advanced' ECUFlash 400
Remote Tuning 'Simple' - ECUFlash 300
Remote Tuning - 'Advanced" ECMLink 350
Remote Tuning - "Simple" ECMLink 250
Sparktech Coil-on-Plug (Standard Version) 325
MagnaFuel 750 Mechanical Drive Electric Fuel pump 650
Black Magnus Fuel Rail 120
New Rix 2000cc Fuel Injectors 575
Hallman MBC 50
Blacktop CAS with Frontline Fab cover 150
EVO cluster with 24551 miles 425
Fp Exhaust Manifold with Hardware 225
Punishment o2 with open dump and Tial Wastegate 325
Tial 50mm BOV - Gold 150
Frontline Fab 2g bolt in fuel cell 875
More photos are available on rixracing.com and again as always need more info info feel free to PM or Txt me!
  • Wanted valve body for 1GA AWD.
    Looking for a valve body for 1GA AWD.
    • kaanevrensel
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
