New wheels, offset, will they rub?
Ballin' GS
223
Oct 12, 2003
Ok i searched. I found the offset calculator online and it said that my new 18x8 rims with a 225 tire will be only 1mm closer to the strut body and 11mm out farther than my 16*7.5's are right now with a 225 tire. Now heres my question, i'm lowered to about .75-1 inch above the tire on all fours and i have never have a problem with rubbing. Are these going to rub now? I know in the back i can roll the fenders, so that is no concern, but what about the front? Will there be enough travel in the suspension that it will rubb around corners?
Probably won't be a problem but if you would supply your tire size and wheel offset someone might be able to help you.
