- Thread starter
- #26
Dopefish
- 4
- Jul 24, 2015
Alvin,
Texas
Thanks.
So in the last week I finally managed to knock out a bunch of maintenance.
I used AMSOIL for everything since I have an account with them and buy their products for one of my other cars.
Maintenance complete:
I also pulled a heat shield off of the exhaust that sits about under the rear seats. It would rattle like crazy so it had to go.
All that's left is to get new tires, an alignment, fix the A/C leak wherever it's at, fix the windows not going up easily, and it should be a pretty solid daily driver. There's still a few things left in the list a few posts ago to address but they're not really a major concern.
- Timing belt replaced along with the water pump and the pulleys that came with the Gates timing belt kit
- Oil filter housing gasket replaced
- A/C system converted to R134a -- replaced high pressure line, drier/accumulator, and all O-rings -- it cools acceptably now but it wouldn't hold a vacuum so there's still a leak somewhere -- there's dye in the system so I'll look at it later to find the leak
- All belts replaced with Gates belts
- Oil replaced with AMSOIL Signature Series 10W-30 Full Synthetic Motor Oil
- Oil filter replaced with WIX Oil Filter
- Coolant replaced with AMSOIL Coolant
- Transmission fluid replaced with AMSOIL 75W-90 Transmission Gear Lube
- Transfer case fluid replaced with AMSOIL 75W-90 Transmisison Gear Lube
- Differential fluid replaced with AMSOIL 80W-90 Gear Lube
- Brake fluid replaced with AMSOIL Brake Fluid
- Clutch fluid replaced with AMSOIL Brake Fluid
- Power steering fluid replaced with AMSOIL Power Steering Fluid
- Fuel filter replaced with WIX Fuel Filter
- Rear pads were metal on metal so I replaced rear pads and cut rear rotors
- Converted rear wiper from that f***ed up pin system to a modern J-hook system. f*** that pin, seriously.
