New Alternator only making .5 volt!
R-U-QUIKR
158
Apr 9, 2002
Calgary,
I put in a new Alt about 3 days ago and it seemed to work fine but now my car keeps dying. I unhooked the battery from the alt and ran the car and the voltmeter barely hit .5 volts on the alternator output. The belt is tight and has grip, is there something that i'm overlooking or is this just a bunk alternator?
Check your alternator FUSE before you do anything, I beleive its 100A or something like that. My blew before and my brandnew alternator wasn't charging anymore. I replaced it and wala!! It was working like a beauty.
^^^ Yeah, the 100A fusible link is a good place to start.
Also, try measuring the voltage from a grounding point on the chassis and the alternator positive output plug to see if you're getting juice that way.
R-U-QUIKR said:
Tryed that got .5volts. Could it be a bad ground? Shouldn't the alt make current as long as it is spinning?
Yes...
Is the plug on the rear plugged in? The plug is there to engage the alternator. If the wires are messed up or disconnected, the alternator won't charge.
Sounds like your new alternator took a crap on you. was it a new factory alternator or just a remand' one from an auto parts store? I had almost the same problem a while back. Take a look at my thread. Hope this helps. Oh BTW, the big fuse is only an 80amp fuse not 100amp.
http://dsmtuners.com/forums/showthread.php?t=184190
