need information? please help with turbo setup
kingdaniel04
36
Sep 2, 2004
phoenix, Arizona
i have been saving money and i need a turbo setup that can put me low 12's or high elevens....i was thinking about a t3/t4 57 trim with a .63 housing...and a turbonetics manifold....can someone help me? what kit should i use that will get me there?
i have a front mount, a 255 fuel pump and afpr and hks mega intake system
I'm not sure what turbo to suggest, I know nothing about garret turbo's, YET :rolleyes: , but I will tell you that you better list all your mods in your profile so everyone can see them. Also I hope that you have some big injectors and some type of fuel management. When you ask questions here you need to be very specific about what mods you have or are going to get before asking about which turbo to get. It also helps to know what year your car is.
Just offering some advice before you get pounded by the rest of the guys :thumb:
Good Luck
I like the PTE 50 trim or the smaller FP custom tubos for a street strip car with your goals. It will have lots of usable low rpm boost on the street and is efficent at moving 20+ psi at the rack to lay some good numbers down.
Low 12's high 11's sounds like a 50 trim TO4E with a .63 A/R turbine housing. No need to mess around with 54 trim or 57 trims. And of course you will need injectors and at minimum an AFC to control them.
thanks guys what do u guyz think about a garret t3/t4 57 trim with a 63 ar housing?
didnt every single person just recommend a 50trim? Reason being, the 54 and 57 trims arent most peoples first choice. Id never bother running one. I did 12.3 on pump gas on the 50trim at 23psi. Bald tires, blown suspension, stock cams, stock manifold etc. No need for more to hit your goal.
i was just asking about the 57 trim because that is what is on sale right now....so i was wondering also if that turbo would do the trick? but now im going to get a 50 trim.... thanks guyz for the help!!! :thumb:
