Need info on fmic couplers.
thakingcb7
196
6
Feb 8, 2015
Lewistown, Pennsylvania
I just bought a SBR short route fmic from a guy I work with but there's no couplers. I know they're 2.5in but I don't know what angles I need. I believe there's 2 90's for the hot side but don't know what goes on the cold side. Any help would be greatly appreciated.
Nobody is going to be able to help you with this without pictures of the pipes or a drawing or something. Your best bet is to just mock it up. Lay everything out how it would be on the car and the angles you need should be clear.
SBR race. The kit isn't the best fitting kit and I'm in the process of redoing the entire upper tubing. Also, make sure the endtanks don't crack at the welds.
