need help with TMO ecu
awd_rs
Nov 23, 2002
I need some help getting in touch with some one from TMO or if some one can help me . My tmo ecu has been giving me trouble by automaticly going into valet mode , i say this because it it happens 90% of the time and im not even in the car when it shuts off . Then when i try to put in my code to start it it will not take it , it stays in valet until i unplug the ecu to reset it . I want to know if i can bypass the security of if there is another fix .
1g turbo 5spd
Sad to say TMO is out of business. Also I will say that the code think can be very fickle. There are times I can get into mine and it will crank the first time. Then there are other times I have to try it like 10 tims. You are cutting the key off after so many trys right?
