Need help with T25 Oil line upgrade
Deathmug
117
Sep 20, 2004
Bremerton, Washington
Hey guys, I'm replacing my stock fee lines with an SS line. I was told by SBR that the oil feed size on the T25 is 1/8" NPT. The 1/8" fitting I am using seams to be too small to tighten down all the way.
Does anyone know what the size is supposed to be?
I think the actual size is 1/8" BSP (BPT) british pipe thread, I found out the same thing when I went to instal my oil pressure sender for my autometer gauge. Ill find out for sure when I get off my lazy butt and order an adapter.
SlowSpyder said:
oil feed on turbo is 7/16" 24 inverted flare
You are correct SlowSpyder! It is in fact 7/16 with 24 inverted flare.
I was able to get the needed fittings from a local break shop. I just got a male to male 7/16 to –4an & a 90 degree –4an female to –4an male with a swivel so I didn’t have to remove the turbine housings to get it on there.
Looks like that question finally got answered. Check out all the guys left hangin about this.
http://www.dsmtuners.com/forums/showthread.php?t=235963&highlight=sTOCK+OIL+FEED+SIZE
http://www.dsmtuners.com/forums/showthread.php?t=196772&highlight=sTOCK+OIL+FEED+SIZE
http://www.dsmtuners.com/forums/showthread.php?t=192263&highlight=sTOCK+OIL+FEED+SIZE
http://www.dsmtuners.com/forums/showthread.php?t=191344&highlight=sTOCK+OIL+FEED+SIZE
http://www.dsmtuners.com/forums/showthread.php?t=179948&highlight=sTOCK+OIL+FEED+SIZE
There’s more, but I didn’t want to spam it up too bad.
    • Sdcryan1
