Need help with electrical issues and vacuum lines
punk3rz
213
95
Jun 1, 2012
Tennessee
Talon pictures by PuNk3rz - Photobucket
1995 Eagle Talon TSi, AWD, 5spd, 140k
I just bought this car for $500 because it wouldn't run and the owner couldn't figure out why.
After checking the fuses, the main 100amp fuse was blown. I believe this is what was causing it not to start although I could be wrong.
Would that fuse cause it to crank but not start?
I have a few questions, and I tried searing for a vacuum diagram but couldn't find one.
Are all these vacuum lines hooked up correctly? Notice, one is blocked off with a screw. I'm guessing it is an EGR removal or something.
I found this wiring dangling, and I'm wondering where it goes. Is it positive or negative?
Should either of these be hooked up? My buddy told me the vacuum lines were fine but there should be a sensor on that 2 prong one.
What plug is this? Where does it go, and what does it do?
There is also a black and a red wire coming from the harness that were just hanging there as well. What would this be?
Thanks to anyone that can help me.
Normally I wouldn't have this problem, but I bought the car like this and have no idea where they go. :ohdamn:
as for the two coming from oil filter housing one is a coolant line also??
You asking your question in this thread has caused some confusion, i think he is talking about his setup and you are under the assumption that he is trying to answer your question. It would be a good idea for a mod to delete a few post's in this thread so that it isn't so confusing.
Ordered injector o rings today, and got the bolts. Tomorrow I may beable to put it back together. I have another question though, what size bolts are the ones that hold the header on? The guy I bought it off of has all the screws thrown in a cup and the screws don't seem to fit right and I don't wanna strip out the head so i may need to get new bolts. I have the bottom studs, just not the top...
There are
(7) M8 studs
(7) M8 flat washers
(7) M8 pinchnuts
(2) M10 studs
(2) M10 flat washers
(2) M10 pinchnuts
Like this
EXTREME PSI : Your #1 Source for In Stock Performance Parts
For good measure you might put a little RTV on the stud which is in the middle, bottom. That stud threads into an oil drain back from the head. Although, I didn't go RTV and haven't had a leak but some people do -just lettin' yaknow.
BUT be careful tightening if aluminum threads are coated with oil, as it's pretty easy to strip
Now would be a good time to check over that tubular mani for cracks etc. ;)
I've gave a description in my first post. No one has really answered any of the questions... still concerned about these random wires... also the temp sensor wire wont reach the temp sensor? Not exactly sure why but i guess I'll just have to lengthen them.
Yup, nothin :sosad:
Sorry we must have missed this. No it won't cause that. The fuse gets blown usually when someone changes the alternator without pulling the battery first.
It's a 1G throttle body on 2G manifold as mentioned. Looking at this link, covers why the screw is there and it shows that particular TB uses the same vacuum diagram as your original TB which is likely still plastered on the underside of the hood. If the diagram is not there, here it is
Power steering pressure switch
http://www.dsmtuners.com/forums/151542320-post48.html
The plastic thing is a California emissions requirement, works fine disconnected. Coolant sensor needs be hooked up that's most likely causing a no start.
Also, flush the cooling system you have some heavy electrolysis starting
The plug is for fog light. Where does the black/red wires go?
Fram filters are known to be thin and rust out by the way
Yea I know, the previous owner was the one who put that POS on it LOL I hate fram. And I said didn't really. Not to specific. Plus I've been on my phone and Haven't really been able to see the sites people have posted. But my main thing is the random wires hanging everywhere... Either way, my turbo comes in on Tuesday and I'll try and put it back together then and see if I can get it running. It's probably out of times because the kid that had it said he doesn't know if it's even in times. So I'll check all that then and if I have any other questions I'll post back. Thanks for the answers.
To tell if it's in time, pull out the spark plugs for one. Turn the steering wheel to the left to gain access to crank pulley. I forget the socket size but turn the pulley until the marks line up at 0* on plastic indicator scale. The marks are little cuts in the balancer. Now look at the camshaft gears, the dowels pins should face straight up and the marks will face eachother like this. Try not to turn the engine backwards, there's a good chance of jumping belt teeth that way
If it was out of time, chances are it has already been cranked over and any valve damage has already been done. Can you do a leak down test to confirm?
http://www.dsmtuners.com/forums/articles-engine-fuel/338152-compression-leak-down-testing.html
No. The sensor located in the thermostat housing that you took a picture of
That could cause a no start as mentioned before and- isn't that mentioned in the link too?
Before wasting time messing with the Cas, I would check the compression. Some people in this thread thinks a motor only requires fuel and spark, but there is a third equally important aspect called compression. Grab a compression tester and post the results.
If you would start answering some questions you wouldnt have to buy random parts. If the car ever ran with the CAS installed, then its already wired correctly.
Mchustle, its been covered. Whether the OP takes the advice or not is up to them.
If it was out of time, chances are it has already been cranked over and any valve damage has already been done. Can you do a leak down test to confirm? Compression and Leak-Down Testing
I don't understand why you would buy a cps not knowing if it was the problem???? Also IF it does have a 6bolt swap I hope you didn't buy a cps for a 95 or you wasted money. Go in this order compression test, then check the Cas wiring (not buy a new one off the bat). Wiring in the Cas is 4 wires so it's not hard to follow them and make sure it is wired in correctly or rewiring it all together. It took me all of 15mins to wire my Cas, and that includes soldering the wires and heat shrinking it and tucking it under the fuel rail.
Also, there is a sensor on the TB. Looks like a temp sensor. Does this need to be hooked up? And can someone pm me there number to where I can text for quick responses? I'm about to start work on it and don't wanna have to come in the house after every problem...
NHerron covered most of it.
Take a picture of whats on the throttle body. How are your timing marks? You should do a compression test after you verify the timing is dead on. Like stated the hanging wire is a pressure switch. Replace ALL blown fuses. Either eliminate or make sure you have zero vaccuum leaks. The ECT sensor you had pictured is VERY important to your car running.
