need help with a few suspension questions
slider85
469
May 21, 2004
Langley,
First off I am planning on doing a suspension overhaul to my 93 Laser 2L NA FWD. I want to do springs, shocks, mounts, and bushings plus anything else that should be done like tie rod ends and ball joints.
Question #1: Does my car have a front anti-sway bar? And, if so, who makes a good replacement one, Suspension Techniques or what?
Question #2: I want to replace whichever bushings I can with polyurethane ones so I need to know which ones I should get or if I should just buy the entire kit? Basically, is it worth replacing the rear sub-frame mounts if it the cost outweighs the benefits?
Any info/advice for me would be much appreciated. If anyone who has redone their suspension has any advice go ahead and post it.
Ps. the parts I am planning on using are Eibach Pro Kit Springs, KYB AGX's, polyurethane bushings full kit, and stock replacement shock mounts and bump stops.
just a follow-up question.
How long does it take to replace all of the suspension bushings?
    • Sdcryan1
