Need help wiring LC-1 Wideband to DSMlink
rgurleyjr81
64
Jun 7, 2005
Moss point, Mississippi
Posted: Sat Oct 15, 2005 1:32 am Post subject: Need help installing LC-1 wideband
I'm having trouble figuring out where the 7 wires go.I have an Innovate LC-1. Are some of the 7 wires not going to be used when running the program on DSMlink? Here are the 7 wires as per the manual:
1)12v supply- I know where this goes.
2)heater ground- chassis ground right?
3)system ground- where does this go?
4)Analog out 1- rear O2 input in ecu harness right?
5)Analog out 2- spare one, no need to hook up?
6)Analog ground- ground where?
7)Calibration wire- n/a
Also, I read about having to input 0.5 or something, is that done on dsmlink? Do I even have to install the software that came with it?
_________________
  • Wanted 6 bolt NT water pipe
    • chrisman287
