Need Help Installing Autometer Phantom EGT
wimploki
303
9
Mar 25, 2005
SoCal, California
I currently have everything setup except for one thing...the RED wire! I need to know where to run/tap the 12V (+) wire positive.
There are 6 total wires.
White Wire for 12V Lighting - this is no problem. Have this tapped and ready to rock.
Black Wire for Ground - no problem with the install as well
Yellow and Red wire connects to probe = very easy
2nd Red wire - Not sure where to tap this wire!!! the manual states - to 12V (+) positive? ok?WTF
Black - Again a good ground source
If you have one installed or have installed one in the past, please advice.
12(+) means hook it to a battery source that will always be on. I ran a wire from the gauge to the battery for mine. I am sure there are other circuits though that are 12v constant I'm just drawing a blank now.
YOu can tap the res wire to the ignition harness... test light the wires for the right one.... I can look up the color tomorrow at work if needed
