blcknspo0ln
DSM Wiseman
- 7,772
- 101
- Jul 31, 2003
Central,
New Jersey
Okay, after all this time with getting my head semi-rebuilt, new timing belt and components, ARP's and a new HG, I put everything back together and now the car won't start. She turns over but won't ignite... Here's what I've done to diagnose the problem, maybe someone out there can suggest something else?
1. plugs/wires OK
2. timing is right on, double checked 100000 times
3. ignition coil pack OK
4. resistor plug OK
5. definitely getting fuel (all over plugs after cranking)
6. Compression is 165-165-165-160
7. NO SPARK to any cylinder via checking with plug wires
8. new cam position sensor (may be 180* out, but I keep switching it back and forth every step I go)
9. Crankshaft position sensor was broken, but replaced with one from Mitsugraveyard (will replace with new OEM soon).
10. all connectors on harness plugged in
anyone? I can't figure out why this sumbitch won't start..
1. plugs/wires OK
4. resistor plug OK
. but as for all that, i still don't know how to check to see if the coil is getting power, and whether or not the ower is getting to the output end of the coil. if anyone has any idea how to do this, i would apprecitate some advice.
