Need help choosing a torque converter
DanGST
352
Oct 8, 2010
Bronx, New York
I am in need of a torque converter. i was looking at
TRANS SPECIALTIES : MITSUBISHI F4A33 TORQUE CONVERTER TS-CT13 Remanufactured and rebuilt automatic transmissions, transmission parts and torque converters
or
TRANS SPECIALTIES : MITSUBISHI F4A33 TORQUE CONVERTER Remanufactured and rebuilt automatic transmissions, transmission parts and torque converters.
One is
11'' DIAMETER, 110 TOOTH RING GEAR, FLATS ON HUB, 4 RECTANGULAR LUGS WITH 10MM X 1.50 THREADS ON 8 1/2'' BOLT CIRCLE, 1.060'' PILOT, 20 SPLINE, CLUTCH OMITTED-INK CODE****LK****
and the other is
10 7/8'' DIAMETER, 110 TOOTH RING GEAR, 4 MOUNTING LUGS ON 8 3/4''BOLT CIRCLE, 1.060'' PILOT, FLATS ON HUB, 20 SPLINE TURBINE, CLUTCH TYPE UNIT-INK STAMP CODE****NR****
they both said they are for the f4a33 but there isn't one for the w4a33. So, i called but the guy i spoke to did not know either. So, i want to see if anybody on here knows which one to get.
right now i dont have enough for the ipt so i was trying go a little cheaper; also i know the f4 is for fwd and w4 is for awd but both says f4 so i didnt know if both works for my car which is a GST or even if one is better then the other. Both of them are price the same.
