need help car randomly sputtering????
cutty2fast
174
May 26, 2010
ocala, Florida
been searchin for a while now cant find anything when im driving my car normal not under any boost just cruising along it will all of a sudden start spuddering like a loud purrr, but if i press in the clutch and let it come down to idle, then let the clutch back out it will run smooth for a bit, then randomly it will do it again :confused: did a compression test before work today it was 150 all across the board plugs where like new has a exhaust leak i need to get fixed near the turbo but it didnt give me a problem drivin 2 hours back from tampa, the motor is a 91 6bolt 16g turbo 550cc injectors stock everything else any ideas
been searchin around found a page got me thinkin the cas is trowin a misfire code?
unhooked the battery today and hooked it back up running great now
