Need hale FAST!! How to fix a Knock Sensor!
illtww
Nov 2, 2002
I accidently pulled the wire out of my knock sensor. It look as if it has a RED wire (sensor) wiht a black wire (Ground)..
ANyone have any pics or diagrams of the 1g knock sensor?
Thanks,
Travis W.
depending where you pulled the wire out you may be able to repair, if you pulled it out of the sensor your basically screwed, because the wire to the knock sensore is like cable cable tv wire, ground around the signal
