Need fuel pump education
sledge42hammer
105
Sep 23, 2010
arlington, Washington
I was searching MAP's website for a fuel pump and when i a came accross them, there are 255 walbro high pressure and 255 walbro NON high pressure. My question is what are the differences as far as application goes? I want to make sure I get the right one. Thank you my fellow dsmers
Sledge
High pressure is what you need. If you need. Im just gunna tell you this.
The HP pump's flow doesn't drop off as hard at higher fuel pressures.
Probably because DSMs aren't the only cars in the world, maybe some cars can take a 255 without an adjustable fuel pressure regulator (some DSMs do it too, though it's not recommended). And now someone that does run a 255 (not HP) without AFPR will chime in saying it's fine. On naturally aspirated applications you'd have no reason for the HP either.
