need biggest drop springs
GSXRACER20PSI
133
Dec 29, 2004
MARLBORO, New York
i want the biggest drop springs for my gsx. i looked around but most of the spring i have found have like 1.5 inch drops. so i was wondering what the biggest drop springs on the market were for my car.
sportlines will give you a pretty big drop.If i was you,i would just get some ground control coilovers.if you vhange your mind about the height,which most likely you will after droping your car more than 2",you can always just raise it to a comfortable level.Remember,if your too low,you'll be hoppin around,and if your hopin around,your tires aren't making contactwith the ground and you'll actually handle worse.
I have goldline springs on my 1g and they lowered it 2". Im pretty happy with them but I am more cautious when looking for potholes.
if you really wanted you can go with adjustable coils and drop it 4...but i wouldnt reccomend it...
i have aerospeed springs dont hop much but the ride isnt to comfterble, I bought the car like this, they are cheap and gave me about a 2.5 inch drop all around i get stuck on most speed bumps so i plan on changing them once i fix my cars phantom voltage drain. i have a 2g 99
My car is red. This is my friends car my drop is a little bit lower he has a 2.25 i got a 2.5
FYI, I have sportlines for sale, PM me for info if you'd like. I bought the car with them on, and it was way too much of a drop for me. I could just barely squeeze one finger in the wheel well with them on and I bottomed out a lot.
Steve
if all you care is the biggest drop, then might as well just take off your stock springs and cut it. Its free :thumb:
its even rides better than most cheap aftermarke springs/shocks combo.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
