Need a quick hand with a MBC on my setuP!! PIC Inside!
if you are going to a Manual controller, you dont use the top nipple.
run the compressor outlet to the MBc, and then into the side port,
thats it.
Well i ran it the same as my greddy solenoid and it works perfect so id say if it works perfect then leave it alone LOL!
i dont see how it would work in the pic you drew, mabye i am missing someting, LOL.
you want unlimited pressure pushing UP on the diaphram, and the same pressure pushing down, IE holding it in place, then once the desired boost is reached, you want the pressure ontop to stop, so the increasing pressure on the bottom would push the diaphram UP, and open the plunger,
if you have the MBC hooked to the top nipple. the gate is going to stay closed Until the spring pressure is reached, then it will open.
with an EBC, such as my sbc ID III, it keeps constant pressure on both sides, then once the set psi is reached, it stops pressurizing the TOP nipple, allowing the boost to push the plunger up.
The MBC is limiting boost going Into the top nipple, and full boost is hitting the bottom, pushing up.
what PSI spring do you have, and is that the boost you are running ;)
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
