Need A Compressor Map
This is the only compressor map I could find of the 56-trim comp wheel: http://www.stealth316.com/2-3s-compflowmaps.htm#fm - scroll down until you see the "Flow Maps in CFM" title, or just hit control+f and search for GT GT42 56-Trim . The airflow is labeled in CFM, not lbs/min, so you may want to find the conversion calculation for CFM to lbs/min.
